SSL VPNs
Mar 18th, 2010
I'd to use the same default logon page with an SSL VPN but based on group membership get the connection profile for that group. I know it can be done by the dropdown box when you permit the user to select the connection profil but I'd prefer not to use this method.
Erick Delgado Thu, 03/18/2010 - 08:37
If you are using a radius server or ldap you can configure attribute 25 class that will let the ASA know what group policy to use.
This is a very simple and helpfull attribute.
If this is what you need please let me know.
