Guest Access Certificates with Multiple Controllers
Answered Question
Mar 18th, 2010
  • Silver, 250 points or more
So I have an interesting scenario to run by the group, I haven't done this but was wondering if anyone else had tried it.
Scenario: is 5 WLC's running 6.0.188.0, One guest SSID, and One H-REAP guest SSID.
WLC#1: SNMP Name is WLC01, Virtual Interface DNS Name is GWLC.somewhere.com, Virtual Interface IP is 1.1.1.1
WLC#2: SNMP Name is WLC02, Virtual Interface DNS Name is GWLC.somewhere.com, Virtual Interface IP is 1.1.1.1
WLC#3: SNMP Name is WLC03, Virtual Interface DNS Name is GWLC.somewhere.com, Virtual Interface IP is 1.1.1.1
WLC#4: SNMP Name is WLC04, Virtual Interface DNS Name is GWLC.somewhere.com, Virtual Interface IP is 1.1.1.1
WLC#5: SNMP Name is WLCDMZ, Virtual Interface DNS Name is GWLC.somewhere.com, Virtual Interface IP is 1.1.1.1
So part 1 of my question is does the above configuration cause any issues with the controllers?
Part 2 of my question is can you request a single SSL certificate for the hostname GWLC.somewhere.com and install it on all the controllers?
The reason for having the certificate on all the controllers is because of the H-REAP Locally Switched SSID.
Anyone have experience with this, input, thoughts?
Thanks.
Correct Answer by dancampb about 7 years 3 months ago
Yes, when you setup the controllers like that you can use the same cert on every controller.
Overall Rating: 5 (2 ratings)
Correct Answer
dancampb Thu, 03/18/2010 - 08:48
  • Cisco Employee,
Kayle Miller Thu, 03/18/2010 - 08:51
Dan,
     Thanks for the response, have you done this configuration before? Just curious.
Kayle
dancampb Thu, 03/18/2010 - 08:54
  • Cisco Employee,
I have seen TAC cases come in on this exact setup.
weterry Sat, 03/20/2010 - 21:57
I too have seen numerous cases on this.
Bottom line is that as long as your HREAP Guests can resolve GWLC.somewhere.com through DNS (as 1.1.1.1), then this should work.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
