CSM 3.3.1 : IP range or IP Pool in ACL
Answered Question
Mar 18th, 2010
is there anyway to use an IP Range in a ACL?
I know there is Object-group...
I would like to use IP range like the VPN IP Pool.
Is it possible?
cheers
Correct Answer by Panos Kampanakis about 6 years 10 months ago
Unfortunately no.
The ACLs cannot support ip ranges, you can only use subnets with netmasks to group ip addresses.
I hope it is clear.
Overall Rating: 5 (1 ratings)
Correct Answer
Panos Kampanakis Thu, 03/18/2010 - 17:20
Unfortunately no.
I hope it is clear.
