Switch log messages
Answered Question
Mar 18th, 2010
Is there a way to have switches send heartbeat messages to a syslog server? We are trying to setup a scenario that will allow our monitoring servers the ability to know that switches are alive and well. At the moment the switches may not send a log message for a bit of time which results in our monitoring devices thinking they are down. This can be ANY type of message - as long as the monitoring devices sees a log entry from the switches.
Pete
Correct Answer by Giuseppe Larosa about 7 years 1 month ago
Hello Pete,
for L2 Lan switches it is common to ping their management IP address to check that they are alive.
Or also some SNMP queries from time to time to check their CAM table size
There are ways to reduce messages sent to syslog server but not an easy one  to create one every few seconds
Probably with IP SLA or EEM if supported this could be done but it is not a common approach.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/18/2010 - 11:34
  • Hall of Fame,
    Founding Member
Hello Pete,
Hope to help
Giuseppe
