03-18-2010 09:23 AM
I am configuring failover on two ACE 4710 device using a dedicated interface (gig1/4) connected to a switch with same VLAN. Below are my ACE ft config:
ACE1:
Admin context
interface gigabitEthernet 1/4
ft-port vlan 30
no shutdown
ft interface vlan 30
ip address 9.9.9.1 255.255.255.0
peer ip address 9.9.9.2 255.255.255.0
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 20
ft-interface vlan 30
ft group 1
peer 1
priority 200
associate-context test
inservice
test context
ft track interface track_vlan14
track-interface vlan 14
peer track-interface vlan 14
priority 200
peer priority 100
ACE2:
Admin context
ft-port vlan 30
no shutdown
peer ip address 9.9.9.1 255.255.255.0
no shutdown
ft peer 1
heartbeat count 20
ft group 1
peer 1
peer priority 200
inservice
test context
priority 100
peer priority 200
Below is the ft peer result:
LB# sh ft peer summary
Peer Id : 1
State : FSM_PEER_STATE_DOWN
Maintenance mode : MAINT_MODE_OFF
FT Vlan : 30
FT Vlan IF State : UP
My IP Addr : 9.9.9.1
Peer IP Addr : 9.9.9.2
Query Vlan : Not Configured
Query Vlan IF State : DOWN
Peer Query IP Addr : 0.0.0.0
Heartbeat Interval : 300
Heartbeat Count : 20
SRG Compatibility : INIT
License Compatibility : INIT
FT Groups : 1
ACE are configured in one arm mode. The problem is ft IP is not reachable from any of the ACE. I am getting arp request on the switch but not on ACE devices. Not sure what's the problem.
Pawan
Solved! Go to Solution.
03-22-2010 05:02 AM
verify that your interface on your switch is configured as trunk?
I had a similar problem where FT was correctly configured but no traffic was being passed.
Changing the switchport on the switch to trunk solved my problem, nevertheless the port on, the ACEs were not configured as trunks.
It seems that it trunks by default.
HTH,
Dario
03-22-2010 04:39 AM
Could anybody suggest any solution? I have it's not the problem with the switch connectivity as I can ping the interface if I use them for data traffic.
Pawan
03-22-2010 05:02 AM
HTH,
Dario
03-22-2010 06:00 AM
Thanks Dario. After making switch interface as trunk port, it started working.
03-22-2010 06:01 AM
Glad I could be of any help.
Thanks for the rating!
