VPLS connection to CE
Answered Question
Mar 18th, 2010
Does anyone know if you can have a VPLS connection terminate on a Cisco (3800, 7200) router running dot1q encapsulation on a sub-interface?
For instance, a gigabitEthernet interface with a sub-interface configured with encapsulation dot1q XXX native where xxx is the native vlan of the VPLS link.
Is this possible, or even recommended?
Correct Answer by Giuseppe Larosa about 7 years 6 days ago
Hello James,
if you mean to use the C3800 or C7200 to connect as CE node to a VPLS link provided by a Service Provider the answer is positive.
But C3800 or C7200 don't support VPLS as provider side device.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/18/2010 - 14:47
  • Hall of Fame,
    Founding Member
Hello James,
Hope to help
Giuseppe
JAMES HAYNES Fri, 03/19/2010 - 06:41
Yes, Giuseppe I was thinking of using the gigabitEthernet interfaces as a CE node connected to a VPLS link provided by an SP.
Thank you fr your help.
-Jim
