RVS4000 Port Mirroring
Mar 18th, 2010
When setting up port mirroring it appears that only the RX for the port is mirrored.  Most devices that I've worked with allow for "[rx|tx|both]" options on the mirrored port.  Is there a way to setup the RVS4000 to mirror both TX and RX for a single port?
mdobiac Wed, 03/24/2010 - 06:24
Though this is straight from the administration guide:
Mirror Source Use this to enable or disable source port mirroring for each port on
the router. To enable source port mirroring on a port, check the box next to that
port. To disable source port mirroring on a port, leave the box unchecked. The
default is disabled.
Mirror Port Select the mirror destination port from the drop-down menu.
However if you are not given the options by default it should be set at both.
I will try to confirm this and get back to you.
Thank you,
Mike
eroomnivla Thu, 04/08/2010 - 10:03
I too am experiencing the exact problem. This is extremely frustrating when port mirroring was the primary feature for which I purchased the product. In fact the only reason that I replaced my functional existing router was so that I could mirror and examine external traffic. Cisco, please inform us how to achieve full port mirroring or how soon a firmware update addressing this blatant problem will be released.
Alvin
