MSM Permissions to Message Store
CUCM 6.1.4
Unity version = 5.0(1.0)
Cisco Message Store Manager=1.4.0.38
Gentlemen:
On both of my Unity Servers, I am running Unity Tools MSM to flush deleted messages more than 30 days old.
The MSM operating successfully a month ago on both Servers, but now it is not able to run for some reason one of the Servers. The one Server will not flush.
The error logs seem to indicate a permissions issue.
I have tried running MSM under all my Unity accounts with no success.
UnityAdmin
UnityInstall
UnityMsgStoreSvs
I thought the UnityMsgStoreSvs would work but it does not.
Again, my other Server works fine..I use UnityAdmin to run MSM on that one.
Maybe I just hosed my MSM app.
Can I solicit a few tips from the experts?
Thanks, Tom
David Hailey Thu, 03/18/2010 - 19:39
  • Purple, 4500 points or more
Tom,
First question and I apologize if it's too obvious, is this a Unity failover pair or two disparate Unity systems?  Also, can you send the error you are receiving on the server that MSM doesn't work on?
Hailey
Please rate helpful posts!
here is a preview ...I can send the file again if needed..BTW i am EST I am leaving in few minutes..
Cisco Unity Message Store Manager Version 1.4.0.38
CMsmDataHelper::GetAttribute(_AVSTR_TASKNAME) failed - Code: 0x80004005. Method: CTaskView::DisplayTasks(). [TaskView.cpp::216]
ITask::Activate() failed - Code: 0x80070002. Method: CTaskHelper::OpenTask(). [TaskHelper.cpp::130]
CMsmDataHelper::GetAttribute(_AVSTR_TASKNAME) failed - Code: 0x80004005. Method: CAgentView::DeleteAgentTasks(). [AgentView.cpp::431]
David Hailey Wed, 03/24/2010 - 16:07
Unfortunately, these are a bit cryptic without doing some further research.  Unfortunately, the MSMConsoleDiag.log captures low-level diagnostics and errors and is geared towards Cisco Unity engineers for troubleshooting.  It is a TAC supported tool so that is an option here as well but...
Here's what I would try first and foremost (if you haven't already).  You are 2 revs behind the latest MSM tool.  I would download the latest MSM and install it on this server and see if you have the same issues.  When you do this, be aware of the following:  If you install a new version of Messages Store Manager in a directory different than the directory in which an earlier version was installed, you will need to copy the data file MSMDATA.XML from the old directory to the new directory to use the settings already configured.
You could also use the Check Mailstore Access function to ensure your rights on the mailstore have not been changed inadvertently.  This can be done on your current version or the upgraded version.
That's how I'd go first and I'll see what else I can dig up for you.
Hailey
David, every thing looks in order. Please see my logs and pics.
I am at the latest rev. now
TAC is stumped on this one too
I have tried about everything:
Deleting and recreating agents
Running with different users
TAC did run the Exchange permission Wizard and there were many failures at first,
but I think it is correct now
It has to be something silly…I will keep working on it.
MSM Lives here
D:\CommServer\Utilities\MessageStoreManager
I have one MsmData.xml in the
D:\CommServer\Utilities\MessageStoreManager directory
David Hailey Thu, 03/25/2010 - 17:46
Sounds fishy, especially since it was working before (I think I remember you saying that).  I'll mess around on my lab server this weekend and see if I can recreate some sort of error scenario.  Probably will be very hard to do but worth a shot.
Good luck - let me know if you figure it out.
Hailey
