03-18-2010 01:11 PM - edited 03-19-2019 12:38 AM
Just configured Unity Connections Visual VM.
2 Server HA setup, follow document and confirmed each test step.
Phone gets "Error, Contact Administrator"
Any ideas, document only says wait 1 minute
Solved! Go to Solution.
03-18-2010 06:02 PM
Make sure from the config guide that you've:
- tested to make the .Jad file is downloadable (from each server)
- make sure the Service Name and Service Vendor is exactly as specified in the .jad file.
- make sure the service URL is correct e.g. http://
- make sure the voicemail_server parameter is set to the cluster hostname
- make sure that cluster hostname resolves (nslookup) to both pub & sub's IP address.
- make sure the voicemail web service is accessible
I assume the contact administrator error message is before you get any screen asking for the user's phone number and pin (otherwise you probably should enable VVWS traces on the Connection server and start collecting the Tomcat log files). But it sounds like it may not be getting that far. I.e. maybe it isn't downloading the .jad file because of some config error either in CUCM or DNS. Depending on the state of things, you may even want to reset the phone you're testing with (especially after unsubscribing then re-subscribing to the service), just to make sure it got everything.
03-18-2010 01:12 PM
The only step we did not complete is rebooting the CUCM TFTP Servers. Is this necessary??
03-18-2010 01:32 PM
Hey
If it's in the manual, and you haven't done it... might be a start
Aaron
03-18-2010 01:39 PM
yeah , I did restart the TFTP services now, still no go
03-18-2010 06:02 PM
03-19-2010 06:56 AM
Thanks for the great info! The answer was:
The Service name we had was "Visual Voicemail' but the jad file was "VisualVoicemail"
Thanks again!
