Native VLAN mismatch - Cisco 4500
Answered Question
Mar 18th, 2010
Is there a way to modify the syslog levels on a Cisco 4500, similar to what we can do on an ASA?
What I am trying to achieve is to stop logging "native vlan mismatch" without disabling cdp or changing the vlan.
Correct Answer by Lei Tian about 7 years 1 month ago
You don't need to disable CDP, should be good by just disable cdp version 2. It is a global command "no cdp advertise-v2"
http://www.cisco.com/en/US/partner/docs/ios/12_0t/12_0t3/feature/guide/cdpadds.html#wp22712
HTH,
Lei Tian
Overall Rating: 5 (1 ratings)
