UCM 7.1(3) install on older MCS-7825-I1 failure
Mar 18th, 2010
I am trying to install UCM 7.1(3) on an older MCS-7825-I1 server and in the beginning of the hardware-deck results it reports that the Clock Speed of 2800Mhz is not supported and install is canceled.  Is there a BIOS version that I need to be at or a way to change the clock speed for the install to proceed?
Aaron Harrison Thu, 03/18/2010 - 14:13
  • Community Spotlight Award,
    Member's Choice, May 2015
The BIOS is flashed by the install routine, so you don't need to worry about that.
Sounds like you need to upgrade your CPU.
Aaron
David Hailey Thu, 03/18/2010 - 22:58
  • Purple, 4500 points or more
Actually, I'm not 100% sure it's that simple.  I'm not sure if this is still the case but when Cisco first switched to the appliance model, the hardware check during install would check the CPU and if it had been upgraded from the original then the installation would fail.  I'm trying to find a way to validate if this is still true or not; however, in the meantime I would suggest you talk to your Cisco AM to see if they can find out if your server can support install of 7.1(3) with an upgraded CPU.  If so, good.  If not, you've saved a lot of time and some money and know that you need to move to a newer model server.
Hailey
Please rate helpful posts!
dyanuszeski Fri, 03/19/2010 - 08:05
The Cisco specs on the MCS-7825-I1 says the processor speed shout be 3.4GHz.  Ours is reporting a speed of 2.8GHz.  So somewhere in the history of this Call Manager server, did the orginal hardware config disk or an OS upgrade set the speed at 2.8GHz?   and it can be changed?
-7825-I1
David Hailey Fri, 03/19/2010 - 11:38
Actually, there were some I1 servers with your CPU. I have a client
with 2 7825I1 servers. 1 is an ECS server for Unity and it has 3.4 Ghz
CPU. The CCM is an IPC server and OEM CPU is 2.8Ghz.
Sent from my iPhone
On Mar 19, 2010, at 11:05 AM, dyanuszeski
