VSOM camera archive best practice question
Mar 18th, 2010
I'm currently extending our archive record loops and I'm starting to wornder what kind of percent of total disk capacity I should leave as available capacity once i'm done with all of the cameras.  I'm working with a 24TB server which is actually 21.82TB on about 100 cameras mixed of IP and Analog cameras.  The installer left it with about 60% capacity as available.
Thank you in advance.
mcwalter Tue, 08/17/2010 - 14:04
You may have already figured this out but here goes.
You can use Cisco's VSM quote tool to get the best mix for the space you have. Are you 100% recording or using motion/event recording?
Your media server should be set up to use 95% of the available space. That is to say even if VSOM thinks the storage space is totally full it's really only 95%. I believe that is to keep the VSMS from crashing.
Good luck.
Related Content
