2801 router config for NxT1
Answered Question
Mar 18th, 2010
I'm working on a config for a 2801 router with a dual WIC.  (There is another single WIC installed, but it won't be in use for awhile).  This is for a 2xT1 - 2 separate handoffs.  Do I have this correct?  I'm feeling doubtful.
Info from our ISP (IPs altered):
WAN Link IP Address:11.112.9.128
CR Serial INT IP:11.112.9.130
AR Serial INT IP:11.112.9.129
WAN Link Subnet Mask:255.255.255.252
LAN info:
IP Address:11.189.125.8/29
LAN/Ethernet/Gateway IP Address:11.189.125.9
Broadcast IP Address:11.189.125.15
Subnet Mask:255.255.255.248
Current configuration : 2763 bytes
version 12.4
hostname rtr
boot-start-marker
boot-end-marker
card type t1 0 2
logging buffered 51200 warnings
enable secret 5 $1$/sfB$0pa0v16BESTJH70u1Mbs61
enable password <snip>
no aaa new-model
no network-clock-participate wic 2
no network-clock-participate wic 3
ip cef
ip domain name yourdomain.com
username cisco privilege 15 secret 5 $1$64xh$LafBTh0zQ55dz2IArg.qq/
username admin privilege 15 secret 5 $1$kp53$jo8pVGWX8wcAlyd1.sipc/
controller T1 0/2/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/2/1
framing esf
linecode b8zs
controller T1 0/3/0
shutdown
framing esf
linecode b8zs
interface Multilink1
ip address 11.112.9.130 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 11.189.125.9 255.255.255.248
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
!interface Serial0/2/0:0
description multilink 1 interface
no ip address
encapsulation ppp
ppp multilink
interface Serial0/2/1:0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/3/0:0
no ip address
shutdown
no ip http server
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
disable-eadi
control-plane
banner login ^C
Correct Answer by Collin Clark about 7 years 4 months ago
Looks good. The only thing you may have to adjust is the clocking. Most ISPs provide line clocking for the T1s. If the T1's don't come up, try changing that first. Here's a reference for that.
http://72.163.4.161/en/US/docs/ios/12_3/vvf_r/vrg_n1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1001437
Overall Rating: 5 (1 ratings)
jamie_5th Fri, 03/19/2010 - 10:41
Thanks for taking a look Collin, and for the clocking suggestion.  I
did confirm that our ISP provides clocking, so I will make that change on the router.
bc4switch Wed, 06/06/2012 - 12:40
Hi, can someone please explain what is the purpose of each of the following?
   is this the default route to the Internet?
   what is CR?
  what is AR?
Why OP only used CR in his config? Thanks.
Related Content
