Configurate QinQ for 7600 with 67xx Line Card
Mar 18th, 2010
Hi all,
I am setting up my MAN network, I am planing to use QinQ, please advise me some case studies and template configaration. My network device have: 7600 with 67xx Line Card, and SW3560, 3750G, 3750ME,
Best regards,
Vo Minh Thuan
Giuseppe Larosa Fri, 03/26/2010 - 06:47
Hello Vo Minh,
the configuration is described here:
what is important is to understand how it is used:
on customer side the port is configured as a L2 trunk
on service provider the port is configured as 802.1Q tunnel (other end of same link)
one or more customer vlans have to be associated with the customer for transport over the SP network
These vlans have to be different from native vlan vlan# or native vlan tagging has to be enabled on SP network switches.
the service is point to point to carry an etherchannel of two GE you need to use two different customer vlan ids
on the other site the same configuration is done with SP edge port configured as 802.1Q tunnel using the same customer vlan-id
additional configuration is needed to carry L2 signalling protocols like CDP, STP and VTP
SP tunnel ports automatically enables STP bpdu filtering on their side to avoid to take part in customer STP domain.
Hope to help
