QM Voice/Screen Upload
Answered Question
Mar 19th, 2010
Hi All,
I have installed system CM7.1.3b+UCCX7.0.1SR5+QM2.7(2) and configuration QM for endpoint recording.
I've configured upload setting and QM workflow(I don't create archive workflow) and testing during off-peak hour but not the end of day in workflow.
but voice/screen don't upload to server.
Did I miss somthing in configuration?
Correct Answer by Aaron Harrison about 7 years 4 months ago
If you look in this folder (may be sqm, not qm, can't remember... but definitely in common files) on the client PC:
C:\program files\cisco\common files\qm\recordings\daily
You should see three (two audio and one screen) recording for each call. If you don't then it's not recording.
If you do, then you should also see an XML file.
In that XML file is a date/time after which the recording will be uploaded - this is normally set to the end of your peak period for today. So if your peak ends at 8pm, nothing from today will upload until then. Recordings that don't upload after 8pm (i.e. because the PC was off, or there were too many to upload) will upload at a reduced rate during peak times.
Recordings from tomorrow will upload from 8pm tomorrow, and so on.
The exception to this is if you have Archiving enabled - if you try to play a call from today through that, the audio part ONLY is pulled from the client PC immediately for playback, bypassing the upload schedule.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 03/19/2010 - 01:14
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Akatsukinix Mon, 03/05/2012 - 07:42
Hi All,
I'm working on this recording. Now I can see .espx and .XML under C:\Program Files\Common Files\QM\Recordings\daily
(There are some .To.Raw and .From.Raw while the call is being recorded, but when the call is done, those raw files are gone and the leftover is *Raw files. Is this correct? Did I do something wrong?)
And, I'm wondering why there's no recordings in my voice directory (as configured in "Upload Settings" in QM Administrator?
FYI, Earlier, I didn't work like this. I can't see any files in the folder, But I still can be able to listen to the recorded files via supervisor desktop. (And I still can do so up until now)
My UCCX version is 8.5.1 SU2.
Thanks in advance
Best Regards,
