QoS fields in the CMR records are always "null"
Answered Question
Mar 19th, 2010
Hi Experts,
We are running CCm version 6.1.4.
I have enabled the "Call Diagnostics Enabled" service parameter.
CMR records are getting generated. But the following QoS fields are always showing "null" for all calls(internal and external) :
numberPacketsLost , jitter , latency , numberPacketsSent , numberPacketsReceived.
The non QoS fields(such as directoryNum (callingPartyNumber) , directoryNum (finalCalledPartyNumber), pkid)   in the CMR are Ok.
Am I missing any config?
Thanks a lot for your help in this issue!!
Bala.
Correct Answer by Aaron Harrison about 6 years 11 months ago
In the settings of the CAR service (in the database load settings if I recall correctly) there is a check box that says 'Load CDR Only'.
Uncheck that...
They should really have made it a 'Load CMR' check box... this caught me out once...
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 03/19/2010 - 02:47
Uncheck that...
Aaron
balasundaram.k_2 Fri, 03/19/2010 - 03:00
Hi Aaron,
Thanks a lot for your fast reply!!!
You were right!!! After I unchecked the checkbox, I could see the QoS data in the CMR records.
The checkbox "Load CDR data only" is available in System->Scheduler->CDR Load page of the CAR.
Thank you again!!!!
Cheers,
Bala.
Related Content
