int dot11 0 stops working
Mar 19th, 2010
I am using about 19 pieces of
AIR-AP1242AG-E-K9       12.4(10b)JA
Two of them show a frequent failure last time. The radio transceiver stops working suddenly without an obvious
reason. The "WiFi inspector" shows no radio sending, but the show command shows that Radio 0 is up (remote access via
Ethernet remains unaffected):
cw-bp1#sh int do 0
Dot11Radio0 is up, line protocol is up
After reboot the Access Point starts working properly.
Any opinion?
Overall Rating: 2 (1 ratings)
dancampb Fri, 03/19/2010 - 06:21
When the AP is like this do a "show controller d0" and see if beacons and probes are enabled.  You also could look to see if the interface is wedged.
t.fiala Mon, 03/22/2010 - 07:16
Dear dancampb,
thanks for your suggestions. I have read controller d0 right now:
Beacon Flags: 0; Beacons are enabled; Probes are enabled
This is of course the normal status, all radios are working well now.
How to discover  whether the interface is wedged?
BTW since my last post a new failure occured. In this case on the radio
bridge. None of the two involved APs allows a client association. So the
logs are simple and looks as follows - see the attached files.
