6509
Mar 19th, 2010
when we power up the 6500 chassis one 6516 and 6348 module didnt come up.
sh module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    2     1000BaseX Supervisor      WS-X6K-SUP1A-2GE    yes ok
Module 1 mismatch of config and actual type. Ports disabled
Config: 48-port 10/100BaseTX (RJ-45) , Actual: 1000BaseX Supervisor
Insert config module type or do a 'clear config 1'
2   2    16    1000BaseX Ethernet        WS-X6516-GBIC       no  other
Module 2 mismatch of config and actual type. Ports disabled
Config: 2 Port 1000BaseX Supervisor , Actual: 1000BaseX Ethernet
Insert config module type or do a 'clear config 2'
3   3    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
4   4    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
5   5    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
6   6    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
7   7    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
8   8    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      yes ok
9   9    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      no  other
show log:
Module 2 port ASIC 0 failed: Pinnacle Packet Buffer Error
Module 2 port ASIC 2 failed: Pinnacle Packet Buffer Error
Module 2 port ASIC 3 failed: Pinnacle Packet Buffer Error
Module 2 reported diagnostics failure on restart
2010 Mar 19 14:11:03 %SYS-3-MOD_CFGMISMATCH2:*Config:2 Port 1000BaseX Supervisor
2010 Mar 19 14:11:03 %SYS-3-MOD_CFGMISMATCH3:*Actual:1000BaseX Ethernet
2010 Mar 19 14:11:03 %SYS-3-MOD_CFGMISMATCH4:Insert config type module or do a 'clear config 2'
                        21. 6/18/2007,12:24:18: InbandPingProcessFailure:Module 2 not responding over inband
22. 6/18/2007,12:27:22: InbandPingProcessFailure:Module 1 local inband error detected
Steps I tried:
Clear config all
reset the system.
disable and enable the slot.
Reza Sharifi Fri, 03/19/2010 - 08:37
  • Cisco Designated VIP,
    2017 LAN
Hi Parthiban,
Are these new modules you are adding or they already exist in the box and now it does not work.  If you are adding new module, do you have enough power to support all these blades.  What size power supply do you have?
Reza
parthiban chinnaya Fri, 03/19/2010 - 08:42
Hi The whole chassis is new one.
I have tried booting the chassis with just one module [6516] and sup engine.
Still the module desnt come up.
Reza Sharifi Fri, 03/19/2010 - 10:38
    2017 LAN
If that is the only module that does not come up and all theother once are good then you have bad module (RMA)
Reza
parthiban chinnaya Fri, 03/19/2010 - 11:22
one gbic module and rj45 module doesnt come up.
tried swapping these modules in diff slot but still doesnt come up.
3 other rj45 modules works fine.
Leo Laohoo Fri, 03/19/2010 - 16:44
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
I smells like you are running the wrong IOS version.
parthiban chinnaya Fri, 03/19/2010 - 19:14
Console> sh ver
WS-C6509 Software, Version NmpSW: 7.1(1a)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Feb  8 2002, 16:37:46
System Bootstrap Version: 5.3(1)
System Web Interface Version: Engine Version: 5.3 ADP Device: Cat6000 ADP Version: 1.6 ADK: 40
Hardware Version: 3.1  Model: WS-C6509  Serial #: SAL09084387
PS1  Module: WS-CAC-1300W    Serial #: SON04230233
Mod Port Model               Serial #    Versions
1   2    WS-X6K-SUP1A-2GE    SAD05010N3L Hw : 7.0
                                         Fw : 5.3(1)
                                         Fw1: 5.4(2)
                                         Sw : 7.1(1a)
                                         Sw1: 7.1(1)
         WS-F6K-PFC          SAD050206DK Hw : 1.1
2   16   WS-X6516-GBIC       SAL06468KZX Hw : 5.1
                                         Fw : 6.3(1)
                                         Sw : 7.1(1)
Leo Laohoo Fri, 03/19/2010 - 21:02
  • Hall of Fame,
    2017 LAN, Wireless
Whoops!  I think I just shot myself.    Do you have any logs when you boot up the chassis?  Have you tried to use the blades somewhere else?  Have you tried other blades in the same slot or move the blades into other slots?
Leo Laohoo Fri, 03/19/2010 - 22:53
  • Hall of Fame,
    2017 LAN, Wireless
I hate to be bearer of bad news.
Is the blade in question located at Slot 2?  If so, it's RMA-time.
2010 Mar 19 14:11:03 %SYS-3-MOD_CFGMISMATCH1:Module 2 configuration mismatch.  Ports disabled
Module 2 port
Module 2 reported following ports unusable
     port 2 bad
     port 4 bad
     port 6 bad
     port 8 bad
     port 9 bad
     port 10 bad
     port 11 bad
     port 12 bad
     port 13 bad
     port 14 bad
     port 15 bad
     port 16 bad
