Linksys SPA3102 PSTN TO VOIP CID in Italy
Mar 19th, 2010
Dear Support,
We try to setup the call forwarding with an SPA3102, which is working well from PSTN to my phone. Now we have the following problem:
If i forward the call, then the right CID is left, instead of this i see only as caller: sip:[email protected] of my phone. Instead of this i need to see the caller's number.
I attach a file containing the current settings.
Please help us find out the problem.
Gergely Kiss
Voip Telekom Hungary Kft.
Alberto Montilla Wed, 03/24/2010 - 03:25
  • Cisco Employee,
Dear Sir;
Let me try to understand the question. You are trying to setup a PSTN to VoIP GW call, isn't it the case? If so could you please provide also the debug traces for the SPA3102 or the network traces?
Alberto
voiptelekom Wed, 03/24/2010 - 05:11
Dear Alberto,
What we try to do is to link the incoming pstn to voip nr with the caller's
right caller ID. The forwarding is ok, but we have no the caller ID.
Gergely Kiss
kabelnet2 Fri, 03/26/2010 - 05:32
Gergely,
Please read the topic "spa3102 & CID" in this forum. The problem is at the CID handling. We are waiting to the correction almost one year. Maybe you have the same problem.
Regards, Tamás Borlay
Sampo1976 Tue, 11/19/2013 - 04:05
Same problem:
I am having a problem with cid when forwarding pstn call to voip.
I am living in Italy, and my service provider is Telecom Italia. The symptoms I have are the following
1- PSTN call received
2- Phone rings, CID is displayed correctly
3- If the phone is not answered after the 2nd ring (Same call), the CID switches to "Private Name, Private Number"
I am running firmware version "5.2.13" on my SPA-3102".
Francesco
Howard Wittenberg Sun, 11/24/2013 - 19:06
  • Bronze, 100 points or more
  • Community Spotlight Award,
    Small Business, June 2015
Over the years there have been a lot of postings about this problem.  It looks like there may be multiple causes.  Looking at some sip debug traces it seems clear to me that it is sometimes caused by a flakey pstn line and a sensitive SPA3102 trying to decide if the call was answered by a device on the line external to the SPA3102.  In other words a SPA3102 monitoring the line voltage and current then deciding that the call was answered external to the SPA and discarding any caller id associated with the call.  Then the SPA3102 senses more ringing and starts ringing a new call without any caller id.  At least that is my theory.  I am not aware of the solution.
Related Content
