STP
Mar 19th, 2010
I am getting this error frequently on a 6509 switch:
(enable) 2010 Mar 19 08:20:02 PDT -07:00 %ETHC-5-PORTFROMSTP:Port 9/42 left bridge port 9/42
2010 Mar 19 08:20:03 PDT -07:00 %DTP-5-AUXVLANPORTOFF:Auxiliary vlan removed on port 9/42
2010 Mar 19 08:20:55 PDT -07:00 %DTP-5-AUXVLANPORTON:Auxiliary vlan added on  port 9/42
2010 Mar 19 08:21:10 PDT -07:00 %ETHC-5-PORTTOSTP:Port 9/42 joined bridge port 9/42
2010 Mar 19 08:22:07 PDT -07:00 %ETHC-5-PORTFROMSTP:Port 9/42 left bridge port 9/42
2010 Mar 19 08:22:07 PDT -07:00 %DTP-5-AUXVLANPORTOFF:Auxiliary vlan removed on port 9/42
2010 Mar 19 08:22:15 PDT -07:00 %DTP-5-AUXVLANPORTON:Auxiliary vlan added on  port 9/42
2010 Mar 19 08:22:30 PDT -07:00 %ETHC-5-PORTTOSTP:Port 9/42 joined bridge port 9/42
(enable) 2010 Mar 19 08:30:54 PDT -07:00 %ETHC-5-PORTFROMSTP:Port 9/42 left bridge port 9/42
2010 Mar 19 08:30:54 PDT -07:00 %DTP-5-AUXVLANPORTOFF:Auxiliary vlan removed on port 9/42
2010 Mar 19 08:30:56 PDT -07:00 %DTP-5-AUXVLANPORTON:Auxiliary vlan added on  port 9/42
2010 Mar 19 08:31:11 PDT -07:00 %ETHC-5-PORTTOSTP:Port 9/42 joined bridge port 9/42"
The error is reccuring almost every 5 minites.
Any idea of what is causing it and how I should fixe it?
Giuseppe Larosa Fri, 03/19/2010 - 09:46
  • Hall of Fame,
    Founding Member
the connection is not stable.
This kind of messages appear on CatOS when a port flaps the key are the messages like
joined bridge
left bridge
there are other messages because a Voice vlan (auxilairy vlan) is configured for the port.
What is connected on this port?
Hope to help
Giuseppe
ccie_rooky Fri, 03/19/2010 - 10:06
Giuseppe:
The VoiP phone are connected to the ports and the PCs are trunked to the phones ports. So, yes, the auxilliary vlans are configured one these ports.
So what should I do? Reseat the modules?
Thanks.
Ganesh Hariharan Sat, 03/20/2010 - 09:00
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Giuseppe:
Thanks.
The switch generates %ETHC-5-PORTTOSTP syslog message, whenever a link is detected on a switch port and the %ETHC-5-PORTFROMSTP syslog message can occur whenever a link is lost on a switch port.These syslogs are normal informational messages that indicate that a port was removed from or added to the spanning tree.
Note that channeling does not have to be enabled in order for these messages to be generated.
A high number of these messages is an indication that a port loses a link due to a mis-configuration or a connection issue.
Check out the below link for more information about the error message.
http://www.cisco-secure.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/system/message/emsg.html
Hope to Help !!
Ganesh.H
