Aaron Harrison Fri, 03/19/2010 - 09:22
  • Community Spotlight Award,
    Member's Choice, May 2015
You can repoint the Directories URL to another web server which would serve the directories up in a different order.
If you browse to the current directories URL you'll see it's just a list of available directories for that user.
Bear in mind this will break the functionality in 7+ to add custom directories through the web GUI.
Aaron
Please rate helpful posts..
