NAC - wanna test the basic setup - does not work !!!!
Mar 19th, 2010
SCENARIO :
·         I have simple NAC setup with 1 NAC MGR “CAM” and 1 NAC SRVR “CAS”
·         My users are running network 192.168.10.x/24 , and I wanna implement in L2 VG mode. Both NAC MGR and NAC SRVR can ping each other.
·         CAM VLAN 55 = 192.168.55.x/24 , and CAS VLAN 66 = 192.168.66.x/24
·         NAC MGR “CAM”  has only 1 cable going to the core switch and NAC SRVR has 2 cables going to the core switch ( one is trusted trunk end and another is untrusted trunk end) . Created two VLANS 999 and 998 and put each of them on each link as blackhole prevention mechanism described in Cisco docs.
·         I have a Windows 2008 DHCP Server who is giving the pool of IPs for users from 192.168.10.x/24 and it is working fine. Routing in the core switch is also ok.
·         I have SSH and web access to both CAM and CAS boxes.  They are also updating online smoothly.
·         From the GUI, I have created the AV Rules also and CAM shows CAS as connected as well !!!!  My version is 4.1.8  (upgraded from 4.1.3 )
INT VLAN 10 (USER VLAN)  SVI is on core switch = 192.168.10.254 /24
INT VLAN 55 ( MGMT ) SVI is on core switch = 192.168.55.254/24
INT VLAN 66 (MGMT) SVI is on core switch = 192.168.66.254/24
PROBLEM :-
1.       I am not able to download or get the NAC Client software MSI or stub file or ActiveX prompt to download ….
2.       I don’t know how to start troubleshooting at this stage. Please note that My client PC is windows XP machine and the port is already configured to VLAN 100.
I have 1 CORE switch only and my NAC boxes and client are connected to the same CORE switch.
Faisal Sehbai Fri, 03/19/2010 - 13:36
  • Gold, 750 points or more
What's your untrusted vlan, and do you have the vlan mapping set in the CAS yet?
Faisal
game123 Sat, 03/20/2010 - 01:36
VLANS Mapping is done in CAM, i didnt find any field in CAS...
Also, i am copying the switch port configs...  ( a simple logical connectivity diagram was attached also to this discussion already )
VLANS DATABASE
vlan 10
name AuthVLAN
vlan 11
name TEST_VLAN_USER
vlan 55
name NAM_mgmt
vlan 998
name DummyVLAN998
vlan 999
name DummyVLAN999
*** Only SVI is VLAN 10 with network = 192.168.11.x/24 , there is no SVI for VLAN 11  ***
Following ports are configured as follows :-
interface GigabitEthernet2/9
description ** NAS's untrusted interface **
switchport
switchport trunk native vlan 999
switchport trunk allowed vlan 11
switchport mode trunk
no ip address
interface GigabitEthernet2/10
description **** NAS Mgmt interface IP 192.168.66.1 *****
switchport
switchport trunk native vlan 998
switchport trunk allowed vlan 10,66
no ip address
interface GigabitEthernet2/11
description *** Test User Acess Port ***
switchport
switchport access vlan 11
switchport mode access
no ip address
interface GigabitEthernet2/12
description ***** Connected to Eth0 NAM on IP 192.168.55.1 ***
switchport
switchport access vlan 55
no ip address
spanning-tree portfast
spanning-tree bpduguard enable
*** FROM THIS core switch I can ping 192.168.66.1 and also 192.168.55.1 with comfort ***
** Please note that actual IPs are 192.168.x.y  and not 10.10.x.y respectively
Faisal Sehbai Sat, 03/20/2010 - 11:57
Click on CCA Servers, Manage my server, and post the screen shots of all tabs for your CAS.
Faisal
