Remote xmodem
Mar 19th, 2010
I have an old 3640 that I inadvertently uploaded an IOS image to that will not boot. It keeps reloading to rommon. It's part of a lab that has a 3700 series router with console access via an NM-32A. I was wondering if there's any way to do an xmodem transfer over the async line. I know how to use the xmodem command on the 3640 to allow it to recieve the image via xmodem, but am not sure how to send an image via xmodem over the sync link. Thoughts?
Ganesh Hariharan Sat, 03/20/2010 - 09:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Keith,
Check out the below link Hope to Help !!
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600
Ganesh.H
Keith Wood Sat, 03/20/2010 - 10:45
Ganesh,
Thanks for the reply and in a way that tells me that there's nothing that can be done. The site that this equipment is located at isn't manned on a regular basis. Because of that, I don't have a way to do step 4 on that guide. I was wondering if there was a way to emulate the hyperterminal portion through the NM-32a that I have hooked to the console port on that device. Thank you for the information, though!
Related Content
