Place Call to Internal Number
I am a relatively new user of IPCC Express. I am working on a script using the CRS Editor that, when a call comes in, the system will place a call to an internal number and play a prompt to the called number. It currently comes up as unsuccessful when I test it. The script is very small right now as I am just trying to make it complete the call before I add the intricacies.
I have attached both the script and a screen shot of the script.
Thank you in advance,
Matt
Anthony Holloway Mon, 03/22/2010 - 07:46
Remove the Accept step, then just use the active debug button, Step Over (or F10) and tell us what the exception is.
michaelzhq Tue, 10/11/2011 - 15:56
Did you resolve the problem?
I got the same issue - it always goes to the Unsuccessful branch.
Should I choose Outbound as the Group Type when configuring Call Control Group of Place Call Step?
Thanks.
michaelzhq Tue, 10/11/2011 - 15:59
Hi Anthony,
I use Place Call step to call a CSQ and play voicemail to agent. - it always goes to the Unsuccessful branch.
Thanks.
