CISCO ASA 5520 configuration doesn't working
Answered Question
Mar 19th, 2010
My Objectives:
  1. INSIDE  can access OFFICE (mail, billing, application, dns) and  INTERNET
  2. DMZ can communicate with OFFICE and INTERNET
  3. INSIDE and DMZ can access each other (all permissive)
  4. OFFICE can access DMZ especially http (e.g websvr ip is 192.169.109.15)
  5. OFFICE can access INSIDE's web (mrtgsvr IP is 192.168.107.29)
  6. OFFICE can pool snmp and WMI information from DMZ and INSIDE.
I have attached my current config file but it wasn't working. Using this configuration OFFICE and INTERNET is not reachable, not even the router 10.11.10.1
Can anyone help me out there to config my ASA properly according my objectives?
Thanks in Advance.
r3linquish3d
Correct Answer by Jennifer Halim about 7 years 3 months ago
If no translation is required, you can configure "no nat-control".
For traffic from low security level to high security level, you would need to have static translation configured, and it works bidirectionally:
static (inside,outside) 192.168.107.0 192.168.107.0 netmask 255.255.255.0
static (dmz,outside) 192.168.109.0 192.168.109.0 netmask 255.255.255.0
This is assuming that the office ASA firewall is configured correctly.
If you would like to ping through the ASA, you would also need to add the following:
policy-map global_policy
class inspection_default
     inspect icmp
Hopefully the above should allow most of your objectives to work.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Fri, 03/19/2010 - 21:44
  • Cisco Employee,
     inspect icmp
r3linquish3d Mon, 03/22/2010 - 01:19
You are welcome.
Now from OFFICE_LAN firewall im getting INSIDE and DMZ, but from the local lan i can't. OFFICE_LAN side firewall IP is 192.168.2.1 and OFFICE_LAN outside IP is 192.168.108.2 which is connected to router(192.168.108.1).
How can I solve that? any help
Jennifer Halim Mon, 03/22/2010 - 01:28
  • Cisco Employee,
Do you mean you can't connect to DMZ from Inside LAN? If that is a true statement, you need to configure the following:
static (inside,dmz) 192.168.107.0 192.168.107.0 netmask 255.255.255.0
Hope that helps.
r3linquish3d Mon, 03/22/2010 - 01:57
INSIDE and DMZ is working smooth and fine. I am talking OFFICE_LAN.
From OFFICE_LAN_FW, im getting INSIDE and DMZ, but not from OFFICE_LAN.
Jennifer Halim Mon, 03/22/2010 - 02:02
  • Cisco Employee,
Sorry, I am a bit confused from where to where is the traffic. Can you please advise the source and destination subnet, and also share the current configuration on OFFICE_LAN_FW. Thanks.
Jennifer Halim Mon, 03/22/2010 - 03:41
  • Cisco Employee,
Thanks for that.
Here is what needs to be configured:
static (insidelan,insideremotelan) 192.168.107.0 192.168.107.0 netmask 255.255.255.0
static (insidelan,insideremotelan) 192.168.109.0 192.168.109.0 netmask  255.255.255.0
Hope that helps.
Jennifer Halim Mon, 03/22/2010 - 04:17
  • Cisco Employee,
Please clear the xlate table just in case it created a dynamic translation prior to the configuration: clear xlate
Jennifer Halim Mon, 03/22/2010 - 05:23
  • Cisco Employee,
Do you still have the ACL configured with "permit ip any any" on all interfaces?
What about the router? Does it have route for the OFFICE_LAN pointing towards the OFFICE_LAN_FW interface (192.168.108.2)?
r3linquish3d Mon, 03/22/2010 - 05:51
  • ACL is only applied to insideremotelan interface.
     access-group 121 in interface insideremotelan
  • all the necessary routes had been added in the firewall. From INSIDE and DMZ I can access everything and reversly from the OFFICE_LAN_FW, I can reach INSIDE and DMZ.
