LMS 3.2 RME 4.3.1 Inventory collection failing for switches
Answered Question
Mar 19th, 2010
I have 6 switches that inventory is failing for.  They do run the 12.2(33)SXI3 software but I have the CSCtb16925-1.0  patch installed.  I've tried to increase the SNMP timeout for the devices but they still fail.
Ideas?
Chris Jasztrab
Correct Answer by Joe Clarke about 7 years 2 months ago
You did not properly increase the SNMP timeout.  Go to RME > Devices > Device Management > RME Devices, and edit the attributes of the device in question.  Perform an inline edit.  Click on the device name, then change the existing SNMP timeout value to 10.  Then save your changes, and apply them on the previous screen.  Then inventory collection should work.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 03/19/2010 - 12:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post your IC_Server.log.
Correct Answer
Joe Clarke Fri, 03/19/2010 - 15:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
CJasztrabTMW Fri, 03/19/2010 - 18:36
I swear I did that but sure enough when i checked..nope.... it fixed the issue.  Thanks.
