Storm-control broadcast
Mar 19th, 2010
We had an issue few days ago with one workstation sent 9000 multicat packets per second. All of our switches reached 100% CPU. We are using a 4506 running Sup2+. Now we wanted to put back the workstation into the network and see if this will reoccur since we tried to recreate the problem into a lab network but we failed.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
  5 minute input rate 15164000 bits/sec, 9021 packets/sec
  5 minute output rate 9000 bits/sec, 18 packets/sec
     15256214 packets input, 3203804940 bytes, 0 no buffer
     Received 15256214 broadcasts (15256214 multicasts)
First, my question is, is storm-control broadcast work as inbound and not outbound of an interface?
Second, if i configure the storm-control broadcast, will it also suppress multicast traffic? I read an article before that a broadcast suppression also suppresses multicast but I'm not positive if I remember it right.
The IOS I am using (and I guess it's not supported by 4500 Sup2+) only supports broadcast suppression unlike the 3560s that can suppress unicast, broadcast and multicast.
Can anyone help me? Thanks.
John
Giuseppe Larosa Sat, 03/20/2010 - 06:14
  • Hall of Fame,
    Founding Member
Hello John,
yes,  storm control applies inbound.
newer Sup6E has distinct multicast suppression storm control.
Other supervisors including II+ can add multicast suppression to broadcast suppression in 12.2(46)SG using
Switch(config-if)# storm-control
broadcast
include multicast
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/bcastsup.html#wp1052688
Hope to help
Giuseppe
Mo'ath Al Rawashdeh Fri, 10/01/2010 - 09:12
  • Bronze, 100 points or more
Hi Giuseppe,
Are you sure that Storm control applies only inbound? I can see from the date of the post that it's not recent, sorry for awakening old threads. In the configuration guide and command reference I could not see any statements that say storm control is applied only to inbound traffic. So, what I decided to do was to test storm control on a actual switch. The conclusion was that it works for both inbound and outbound directions.
All my respect to you.
Thanks & regards,
Moath,
Ganesh Hariharan Sat, 03/20/2010 - 08:32
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
John
Hi John,
storm-control only works on INBOUND packets and for multicast control you need to configure separetlt on per interface basis (config-if)#storm-control multicast  level (#)[.(#)]
check out the below links for configuring strom control at switch level
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/storm.html
Hope to Help !!
Ganesh.H
Giuseppe Larosa Sat, 03/20/2010 - 08:49
  • Hall of Fame,
    Founding Member
Hello Ganesh,
John has a C4500 router not a C6500 and according to configuration guide the command you have suggested is not available unless you have a sup6E.
I've found that  note about the option include multicast that is specific of C4500.
To be noted from interface counters in original post that broadcast counter counts equal the multicast count.
Hope to help
Giuseppe
Ganesh Hariharan Sat, 03/20/2010 - 09:03
Hello Ganesh,
Hope to help
Giuseppe
Hi Giuseppe,
Oops that was my fault thanks for correcting the post
Ganesh.H
John Patrick Lopez Sat, 03/20/2010 - 22:59
Hey thanks for the reply.
Yeah I saw that option too in some IOS but I cannot find the include multicast command on my IOS version. I also looked at out Sup4 engine and it isn't there either. So I need to look for that article where I read broadcast includes multicast. I don't know if I heard or read it right but I'll try to find out.
