Newbie question - Physical switch / network jack identification
Mar 19th, 2010
Hi everyone
We are in a bot of a bind and I was hoping someone could point me in the right direction, if this is even possible.
We need to be able to identify the Network Jack when a device is connected to it (ultimately identifying the location where the device was connected at that time).  As the devices and locations may change I was hoping it would be possible to set the switch up to forward traffic from a particular port on the switch (which wil corelate to a port on a wal in a specific room) to a specific IP and port on a network server?
Any assistance would be greatly appreciated.
Leo Laohoo Fri, 03/19/2010 - 15:19
Sounds like all you need to do is change the VLAN port assignment of the switch.
glen.grant Fri, 03/19/2010 - 15:21
   I don't know of a way to do that .  The only thing I can think of is to make sure you have  snmp trap link status on all the switchports .  Then have someone in the switch  looking at it with term mon on   and have the person plug the cable in a out a few times and you should see that link going up and down .
