High Memory Utilization Pix 515e
Mar 19th, 2010
Hi to all,
I have a Pix 515E with 128MB in RAM and i've been having an utilization of 98%, at the beggining we had the 7.2 version and doing some researches we found that maybe that high usage could be a bug in that version and we upgrade to 8.0.4.28 but the problem remains.
Here is the sh processes memory output:
AllocsAllocatedFreesFreedProcess
pix#
50276692 1992587007      502207101963801384Dispatch Unit
2583551248463625835512484636vpnfol_thread_timer
1906581565246219029412870196Unicorn Admin Thread
1794063047390813592721569135fover_parse
13467643096321346764309632icmp_thread
45045380899645385828511088tmatch compile thread
120361137964152442491711IKE Daemon
57251849726239285384fover_health_monitoring_thread
562912615785496211913370ci/console
41467343041427246426fover_FSM_thread
1974268464991107252IP Background
9976009298632620Logger
9774439665821056ARP Thread
946977207938975528Unicorn Admin Handler
9279253191990792Unicorn Admin Handler
886129632876180*System Main*
76819351245974848tacplus_snd
6138234438834644NAT security-level reconfiguration
50233404820013200CTM message handler
4842501443719026vpnfol_thread_msg
2363421661708588IPsec message handler
23374562337456ha_trans_data_tx
18059841805984NTP
166916000IKE Receiver
120242512179294fover_thread
83764020917061aaa
51164819608lu_rx
37102175029928lu_ctl
356241417056NIC status poll
2914156595105984rtcli async executor process
2062385900netfs_thread_init
1219200fover_serial_rx
71414438356Integrity FW Task
43116382783396uauth
4416000RADIUS Proxy Listener
3835600vpnlb_thread
38356116listen/ssh
342724825180SNMP Notify Thread
2244240arp_timer
12000radius_rcv_auth
12000radius_rcv_acct
16557200PIX Garbage Collector
1161222928npshim_thread
14000update_cpu_usage
12400EAPoUDP-sock
0000CTCP Timer process
0000radius_snd
0000IP Thread
0038356fover_serial_tx
0000RADIUS Proxy Time Keeper
0000L2TP data daemon
0000Thread Logger
0000ha_trans_ctl_tx
0000fover_rx
0000Crypto PKI RECV
0000block_diag
0000L2TP mgmt daemon
0000TLS Proxy Inspector
0000Session Manager
001134839qos_metric_daemon
0000fover_tx
0000dbgtrace
0000Crypto CA
0000ppp_timer_thread
0000vpnfol_thread_sync
0000emweb/cifs_timer
002073720tacplus_get
0000udp_thread
0000Chunk Manager
0000fover_ip
0000uauth_urlb clean
0000vpnlb_timer_thread
0000vpnfol_thread_unsent
0000tcp_thread
0000Uauth_Proxy
0000fover_rep
0000pm_timer_thread
0000Integrity Fw Timer Thread
0000arp_forward_thread
0038356lu_dynamic_sync
0000IP Address Assign
0000IKE Timekeeper
001541780tcp_fast
0000QoS Support Module
0000fover_ifc_test
0038356557mcfix
0000Reload Control Thread
0000tcp_slow
0000EAPoUDP
0014912SSL
0000Client Update Task
0000557statspoll
0000RADIUS Proxy Event Daemon
0000ICMP event handler
0000udp_timer
0000ssh/timer
0000SMTP
0000Checkheaps
I've been working around with this but i can't make the used memory to decrease, any suggestions??
trippi Tue, 03/23/2010 - 10:39
Are you running threat-detection?
If so, that could be a cause...
alfonso.cornejo Tue, 03/23/2010 - 10:41
I was but i disable it and the problem remains.
Any other ideas?
Thanks in advance
