Konstantin Dunaev Fri, 03/19/2010 - 16:42
  • Bronze, 100 points or more
just try to use "telnet x.x.x.x /source-interface Y"
Richard Burts Sat, 03/20/2010 - 20:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
David
Konstantin has given a good suggestion if you want to supply the source address in the command line. There is also an option that you may consider to specify the source address for telnet using the config command:
ip telnet source-interface
Rick
pompeychimes Sun, 03/21/2010 - 23:28
You can also specify the port...
telnet x.x.x.x 21 /source-interface f0/0
Please rate helpful posts
James
