SPA3102: Call fails with NORMAL_TEMPORARY_FAILURE
mcampbellsmith
Hi!
I am using freeswitch to connect to my SPA3102 which is registered using TLS.  Quite often I see the following, which results in FreeSwitch ending the call with NORMAL_TEMPORARY_FAILURE.
The syslog from the SPA3102 looks like this:
Mar 19 19:58:15 xxx.xxx.xxx.xxx CC:pc(1)=130 not in codec list
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0:0]AUD ALLOC CALL (port=30322)
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0:0]RTP Rx Up
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0]->124.xxx.xxx.xxx:442(519)
Mar 19 19:58:15 xxx.xxx.xxx.xxx SIP/2.0 180 Ringing  To: <sip:2001@xxx.xxx.xxx.xxx:5070;transport=tls>;tag=80a48d552a9b8589i0  From: "anonymous" <sip:anonymous@124.xxx.xxx.xxx>;tag=BFgcyp329X51S  Call-ID: 650ac1cf-add8-122d-71b8-00e04c0312e9  CSeq: 128376211 INVITE  Via: SIP/2.0/TLS 124.xxx.xxx.xxx:442;branch=z9hG4bK2U30XeKBjamap;rport=442  Contact: 2001 <sip:2001@xxx.xxx.xxx.xxx:5070;transport=tls>  Server: Linksys/SPA3102-5.1.10(GW)  Remote-Party-ID: 2001 <sip:2001@mydns.dyndns.org:442>;screen=yes;party=called  Content-Length: 0
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0]SIP/TCP ServerDisconnected:-257
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0]FM Alert Stop RxTx (c=0024e6b0;a=0)
Mar 19 19:58:15 xxx.xxx.xxx.xxx [0:0]AUD Rel Call
Mar 19 19:58:15 xxx.xxx.xxx.xxx CC:Failed w/ Ringing
Mar 19 19:58:15 xxx.xxx.xxx.xxx DLG Terminated 2a8d10
Mar 19 19:58:15 xxx.xxx.xxx.xxx Sess Terminated
Can someone explain why this might be failing?  Thanks!
16 Replies 16
Alberto Montilla
Dear Sir;
Do you have network traces, e.g. ethereal or wireshark??
Alberto
I use TLS, so are pcap traces required?  They won't show much.
I can give you the complete syslog from the spa3102.  Is that enough?
Dear Sir;
Please send the syslog traces. Wont be able to see RTP but it may be sufficient.
Alberto
Hi Alberto,
Please find the logs at http://pastie.org/885651
Mark
Hi Alberto,
Did the logs help at all?
Dear Sir;
I've escalated this, as this has to do with TCP/IP interop. Why are you using DDNS all the way to the device? This is not a normal practice, you either use STUN or fixed mapping (or SBC function at the server).
Stay tuned.
Alberto
Hi Alberto,
Thanks for replying.  I'm not using DDNS all the way to the device for SIP handling - these should have been removed from the syslog.
Looking forward to engineerings response.
Hi Alberto,
Has there been any response from Engineering?
Thanks!
Hi Alberto,
Thanks!
Hi Again,
Please, has there been any updates on this failure?
Hi Alberto,
I haven't heard anything for months regarding his fault.  You stated in March that 'I've escalated this, as this has to do with TCP/IP interop.'
Please can you give me some indication of the status of the investigation.
Dear Sir;
I'm sorry for the delay, the email was sitting on my inbox (my mistake).
One question is that on the trace we see a "130 not in codec list" between the trying and ringing messages. Can you please check this is not causing an issue on your system?
Alberto
Hi Albert,
I still see this problem after shutting down all codecs not being used, and I do not see the "130 not in codec list" anymore.  The fault is still there - see below from the syslog
Jun 22 19:27:35 92.xxx.xxx.xxx SIP/2.0 180 Ringing  To: <2001>;tag=9766c2dbbb305122i0  From: "1000" <>1000@124.xx.xx.xx>;tag=gv0X0eX3jKrme  Call-ID: 3bc7e780-f883-122d-c6a6-00e04c0312e9  CSeq: 132481091 INVITE  Via: SIP/2.0/TLS 124.xx.xx.xx:442;branch=z9hG4bK8K08jFN2FH2Ur;rport=442  Contact: 2001 <2001>  Server: Linksys/SPA3102-5.1.10(GW)  Remote-Party-ID: 2001 <>2001@mydns.dyndns.org:442>;screen=yes;party=called  Content-Length: 0
Jun 22 19:27:36 92.xxx.xxx.xxx [0]SIP/TCP ServerDisconnected:-257
Jun 22 19:27:36 92.xxx.xxx.xxx [0]FM Alert Stop RxTx (c=0024e6b0;a=0)
Jun 22 19:27:36 92.xxx.xxx.xxx [0:0]AUD Rel Call
Jun 22 19:27:36 92.xxx.xxx.xxx CC:Failed w/ Ringing
Jun 22 19:27:36 92.xxx.xxx.xxx DLG Terminated 2a8d10
Jun 22 19:27:36 92.xxx.xxx.xxx Sess Terminated
Jun 22 19:27:36 92.xxx.xxx.xxx RSE_DEBUG: getting alternate from domain:mydns.dyndns.org
Jun 22 19:27:36 92.xxx.xxx.xxx [0]SIP/TCP NewLocalPort:5064
Jun 22 19:27:36 92.xxx.xxx.xxx [0:0]SIP/TCP:Connecting(25)
Jun 22 19:27:36 92.xxx.xxx.xxx [0:0]SIP/TCP:Connect=-1
Jun 22 19:27:36 92.xxx.xxx.xxx [0]SIP/TCP Backoff 500 ms
Jun 22 19:27:37 92.xxx.xxx.xxx [0]SIP/TCP NewLocalPort:5065
Jun 22 19:27:37 92.xxx.xxx.xxx [0:0]SIP/TCP:Connecting(26)
Jun 22 19:27:37 92.xxx.xxx.xxx [0:0]SIP/TCP:Connect=0
Jun 22 19:27:37 92.xxx.xxx.xxx [0:0]SIP/TLS:Connecting(26)...
Jun 22 19:27:38 92.xxx.xxx.xxx [0:0]SIP/TLS:Connect=0
Jun 22 19:27:38 92.xxx.xxx.xxx [0:0]SIP/TLS:Connect OK
Jun 22 19:27:38 92.xxx.xxx.xxx [0]->124.xx.xx.xx:442(787)
Jun 22 19:27:38 92.xxx.xxx.xxx REGISTER sip:
Dear Mark;
Thanks for sending the traces. I'll check with engineering and let you know
Alberto
