MTP -Reason Code 13
Mar 20th, 2010
Can some one suggest for the below error ?
MTP Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node ID:
CFB Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node ID
MOH Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node ID
Regds,
Navin Golani
Jaime Valencia Sat, 03/20/2010 - 14:43
A reason code is useless if you do not mention what error it's from
As there is no version or other info i'd suggest you to read this:
System Error Messages for Cisco Unified  Communications Manager 8.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms801.html
If not your version you can find the right doc under our documentation.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
