Inventory collection failed, LMS 3.2
Mar 20th, 2010
Hi.
There is the failure of the Inventory collection on switch with the following message in RME job log:
"Transport session to device failed. Cause: Authentication failed on device." , but at the same time everything is OK with snmpwalk running from Device center :
__
The following is a SNMP walk of device 172.19.64.11 starting from .1.3.6.1.2.1.1.5
SNMP Walk Output
.1.3.6.1.2.1.1.5
RFC1213-MIB::sysName.0 = STRING: "ENG-av3560-avid-u1.sys.tv-news.lan"
__
Snmp timeout value = 10sec.
Could you explain the reason of this and could you help me to solve the problem?
Joe Clarke Sat, 03/20/2010 - 14:03
Just because you can make SNMP Walk work does not mean the SNMP credentials are correct in DCR.  Start a sniffer trace filtering on SNMP (udp/161) traffic to this device, then perform an inventory collection for it.  The trace file should show why the failure is occurring.
ESSergachev Sun, 03/21/2010 - 04:24
Debug snmp headers on switch show the legal string when Inventory collection job active.
Joe Clarke Sun, 03/21/2010 - 10:33
Then go to Common Services > Device and Credentials > Device Management, select this device, and click the Edit Credentials button.  Re-enter the SNMP credentials for this device.
