Cisco 3550 Switch not booting up
Mar 20th, 2010
Hi all,
I got switch 3550  it is not booting up
i did console no luck then i rebooted while i consoled to switch here is output
File "flash:/c3550-ipservicesk9-mz.122-40.SE/c3550-ipservicesk9-mz.122-40.SE.bin
" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(40)SE, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 24-Aug-07 02:15 by myl
Image text-base: 0x00003000, data-base: 0x011209B0
Initializing flashfs...
flashfs[1]: 402 files, 6 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 10587648
flashfs[1]: Bytes available: 5411328
flashfs[1]: flashfs fsck took 9 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: ILP Controller Tests : Begin
POST: ILP Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
of memory.
Processor board ID CAT0722R1DQ
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0D:28:BC:FD:80
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT072101VJ
Power supply serial number: DTH07220Y3N
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0722R1DQ
no service single-slot-reload-enable
% Invalid input detected at '^' marker.
Reza Sharifi Sun, 03/21/2010 - 07:11
  • Cisco Designated VIP,
    2017 LAN
So the switch does not boot all the way?  What happens when you press enter after the last line (% Invalid input detected at '^' marker.)?
Reza
