Dial Mode in CUCM
Answered Question
Mar 21st, 2010
I installed a 7.0.2  CUCM IP Telephony platform in a company that have an Avaya PBX. In Avaya platform it is possible to dial to internal numbers without off-hooking the phone and without pressing any other key. The user just type the internal number (the phone is on-hook) and the call is placed.
Is there any way to do this in CUCM?
Correct Answer by Jaime Valencia about 7 years 4 months ago
Unfortunately no, in Cisco world you dial the phone and then press dial softkey if you want that without going off-hook.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Sun, 03/21/2010 - 10:45
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Related Content
