How to add an extension module 7916 at UCM 7.1.3
Mar 21st, 2010
Dear Frends
I need to add a extension module 7916 + 7965 phone at UCM 7.1.3, but when I add the module It does´t not work.
I need to add something to the configuration?, I already check the aux port between  the units.
So I think that the problem isn´t  phisical.
I´ll be waiting you answers
greetings Leandro
Jaime Valencia Sun, 03/21/2010 - 19:10
  • Cisco Employee,
  • Hall of Fame,
    2011
Make sure you're running at least 8.3(5) FW on your phone
You need to provide a clear explanation of what's happening, red buttons? problem on CCMAdmin?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
leandro.perez Mon, 03/22/2010 - 08:45
The Extension Module 7916 is connected to the phone, but do not run.
In the UCM in the phone settings configured Expansion Module Information, but not know if I need something else in the module configuration.
I need something else in configguracion?
please any suggestions
THX
