I am running CUCM 6.0(1). Trying (unsuccessfully so far) to setup Mobile Voice Access. I am using a 3745 router as an h323 gateway. I'm probably doing something simple incorrectly. Basic issue is that I can not seem to get to the Mobile Voice Access IVR. I have a DID 5921515 setup for MVA. I created the remote destination profile and setup a cell phone as remote destination. 3801825. When I dial 5921515 from said cell phone I see the dial-peer on the router handing the call off to the voip dial peer but all I hear is constant ringing on the cellphone. My DN for MVA is 1801. An excerpt from my router config is as such:
application
service cmm http://172.16.0.2:8080/ccmivr/pages/IVRMainpage.vxml
dial-peer voice 5921515 pots
service cmm
incoming called-number 5921515
no digit-strip
dial-peer voice 301 voip
preference 1
destination-pattern 1801
session target ipv4:172.16.0.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
voice-port 4/1/0
no battery-reversal
input gain 10
echo-cancel suppressor
no comfort-noise
timing hookflash-out 50
connection plar opx 1801
threshold noise -90
station-id number 8455921515
caller-id enable
I will be converting away from FXO to a SIP trunking provider in the near future and I know that FXO can not work with Mobile Connect but from my understanding is that it ought to work to allow a user to dial in to access MVA? I've seen so many conflicting reports on this feature and have never yet been successful in even getting to the IVR! Very frustrating. I greatly appreciate any assistance that anyone may have in regards to this. Thanks in advance.
