Aniserver Startup
Answered Question
Hello
I cannot open Topology Services because Aniserver process is down.
I haven't been able to start it. When I try, the process seems to be busy for a while but finally It fais
The instructions shown in other similiar cases havent' worked for me.
Correct Answer by Martin Ermel about 7 years 3 months ago
you can try to reinit the topology part of the ANI database to solve this issue; you will loose all your customized maps;
the command to reinitialzie the topology portion of the ANI database:
NMSROOT\bin\perl NMSROOT\campus\bin\reinitdb.pl
with NMSROOT being you LMS installation path (default for windows: C:\Progra~1\CSCOpx)
after that start a new Data Collectio (Campus > Home) and see if the problem has gone;
Overall Rating: 5 (1 ratings)
Martin Ermel Mon, 03/22/2010 - 06:18
  • Blue, 1500 points or more
post the complete output of pdshow.
it seems there are some device inconsistencies.
Correct Answer
Martin Ermel Mon, 03/22/2010 - 10:13
Related Content
