Route VPN site to site on a route other than the default gateway
Answered Question
Mar 22nd, 2010
I would like to route VPN site to site on a route other than the default gateway
Asa 5510
os 8.0 soon 8.3
1 interface line adsl  (surf) default gateway
1 interface line SDSL (10 VPN site to site)
1 interface LAN
that it is possible ?
thank you
Sorry for my English
Correct Answer by Jennifer Halim about 7 years 4 months ago
Here is the assumption that I will make:
- Your SHDL interface ip address is 200.1.1.1, and next hop is 200.1.1.2
- Your LAN-to-LAN is terminated on this interface (crypto map interface SHDL)
- VPN peer 1 - 150.1.1.1, and LAN is 192.168.1.0/24
- VPN peer 2 - 175.1.1.1, and LAN is 192.168.5.0/24
Here is the routing based on the above assumption:
route SHDL 150.1.1.1 255.255.255.255 200.1.1.2
route SHDL 175.1.1.1 255.255.255.255 200.1.1.2
route SHDL 192.168.1.0 255.255.255.0 200.1.1.2
route SHDL 192.168.5.0 255.255.255.0 200.1.1.2
Hope that helps.
Overall Rating: 5 (1 ratings)
Jennifer Halim Mon, 03/22/2010 - 03:20
  • Cisco Employee,
Yes that is possible for the site-to-site vpn tunnel.
The VPN must terminate on the SDSL line interface of the ASA, and you would need to configure the following route pointing towards the SDSL line next hop:
- Route for the crypto peer addresses
- Route for the peer LAN subnets
Hope that helps.
asstec2 Mon, 03/22/2010 - 04:17
Thank you for your response
Could you give me an example for different routing?
Correct Answer
Jennifer Halim Mon, 03/22/2010 - 04:33
  • Cisco Employee,
Hope that helps.
