SGE2000 (horrible) problems.
Mar 18th, 2010
SGE2000 problems:
1) Layer 3 stack routing (?) problem after slave unit restarts.
Greetings!
Firmware: 3.0.0.18
Boot code: 20003
The scheme:
----- LAN1         SGE2000 Level 3 stack:
               `-----------Unit 2 (slave)
                           Unit 1 (master)
                            `----------(ws1)
The problem scenario:
            NB: It is only applicable to the situation when we use different subnets, in other words,
            the Layer 3 functionality of SGE2000 is involved. No such issues appear when all the hosts
            are in one VLAN, whether they are connected to different units in a stack or not.
            If the connection between Unit 1 and 2 is lost (I unplug the cable), slave unit ( Unit 2 ) resets,
            and comes up back to operation as a slave. It's OK.
            But the host ws1 (from LAN2) is not able to communicate to cmputers in LAN1 after the event.
            If I go to the web interface of the stack and do the ARP-table flush, some pings may pass
            but the next second the connectivity is lost again.
            All the ports involved in communication are in "forwarding" state.
            Sometimes, if I do a manual flush on Dynamic table in Bridging, communication
            becomes OK. Sometimes it doesn't help. Even if flushing arp cache too.
            If I unplug ws1 from the switch and plug it back, the connectivity becomes OK.
                 Flushing arp cache on ws1 doesn't help.
            If I restart the whole stack, the connectivity is OK.
            What's the problem with restarting a slave unit? Why the routing connectivity is lost?
2) Another problem is when trying to bind an ACL to the interface
     it simply reports:
Line No.Error TypeValueDiagnostic
1Unknown valueCannot apply because lack of HW resources..
     =) Great!
alissitz Fri, 03/19/2010 - 08:49
This sounds pretty odd, and thanks for explaining everything as you do.
Have you considered calling our support?
https://www.myciscocommunity.com/community/smallbizsupport
Look to the right hand side and you can find the link for the support numbers.  I do not see anything in the release notes as a known limitation or problem ... unless someone on this community has more to add, I would suggest calling our support.
Our support will likely request the configs and system logs (if you have any)
HTH,
Andrew Lissitz
KelvinKN3 Fri, 04/23/2010 - 04:58
I am also suffering from 'Problem 2' applying the ACL to a port.
It was OK - then suddenly has stopped working.  Have saved the config and bounced the device with no joy.
Any thoughts?
satanovskyl Sat, 08/28/2010 - 11:22
UNFORTUNATELY,
regarding to the official Cisco tech support (what comes out of my discussions with them),
all the discussed bugs (see also bugs regarding SRW* ) are
not considered critical, and there are no plans to fix anything in the nearest time.
On ACL problem: they say, take the textual config of the switch (exprot it to a txt file), edit it and upload it back, that's the way to edit ACLs... =)
Sounds promising )
Paul Cobley Wed, 11/03/2010 - 10:54
Hi Leonid,
I have the same error re applying the ACLs at a customer site (Cannot apply because lack of HW resources) which is odd as I removed the existing ACL, editted it then tried to re-apply it.
What was the outcome of your dealings with Cisco support and did you manage to resolve this by using the 'textual config' method ?
If so do you have documentation of the 'textual config' method ?
Many thanks
Paul.
w.surma@pro-sys... Thu, 11/11/2010 - 02:19
1. Check if every numer of your Rule Priority are unique.
2. I think that main rule (original "ACL_IP_Traffic") must be unchanged ( ANY, ANY, ANY, ANY permit) and must have rule priority number = 1.
Related Content
