sql database size cucm 4.3 -urgent help req-
Answered Question
Mar 22nd, 2010
Dear,
Please let me know step by step to check SQL database size in cucm 4.3
regards
Correct Answer by Aaron Harrison about 7 years 2 months ago
Go into SQL Enterprise Manager.
Click on the server, then go into databases and you should see a CCMxxx database. Right click on it and select Properties.
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Mon, 03/22/2010 - 05:19
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
