Upgrade 7961g to SIP Firmware
Answered Question
Mar 22nd, 2010
I need to change the firmware on a 7961g from sccp to a SIP image and I have downloaded the latest version 9.0.2 and it is a .cop.sgn file.   Does anyone know how I get that onto the phone or what I do with it.   All the guide I have found on the internet use .bin and .loads files so I'm a little unsure of what to do or if this is the right thing.
Many Thanks
Correct Answer by markbatts about 6 years 10 months ago
I assume that you just have the phone and not Callmanager? if thats the case then this url should be useful
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
What you have downloaded is the SIP image for a Callmanager running Linux which is no good.What you need is the zip file
which is in the same place you got that file.
Cheers
Mark
Please rate useful posts
Overall Rating: 5 (1 ratings)
Correct Answer
markbatts Mon, 03/22/2010 - 05:50
Cheers
Mark
brianpocock Tue, 03/23/2010 - 08:47
Would you be able to tell me which one I need to download as there were three there, is this the one I need: cmterm-7941_7961-sip.9-0-2SR1.zip
Thanks.
Related Content
