03-22-2010 03:39 AM - edited 03-04-2019 07:53 AM
Dear all,
Fighting during late 2 days with 2811 router. It doesnt recognize inserted 4ESW HWIC module.
IOS version should support this hardware.
Please take a look at routers output.
*Mar 22 09:51:16: %SYS-5-RELOAD: Reload requested by admin on console. Reload Reason: Reload Command.
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x3117470
Self decompressing the image : ## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E7 0X00474800 C2811 Mainboard
0X00264050 Onboard VPN
0X000021B8 Onboard USB
0004F4 0X00016804 Virtual Private Network (VPN) Module
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00BC4BFC
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 4 percent iomem. [12Mb/256Mb]
Restricted Rights Legend
---------------------------------------------------------OMITTED
Installed image archive
Cisco 2811 (revision 49.46) with 249856K/12288K bytes of memory.
Processor board ID FHK********
2 FastEthernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Press RETURN to get started!
*Mar 22 09:53:19.447: %GT96K_FEWAN-1-UNKNOWN_WIC: slot 0, wic card has an unknown id 64
hostname#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 14:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
hostname uptime is 31 minutes
System returned to ROM by reload at 09:51:16 UTC Mon Mar 22 2010
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.T10.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FHK1344F40Q
hostname##sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V07 , SN: FHK1344F40Q
NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2 , VID: V01, SN: FOC13394XRE
Card was normally recognized by other router
03-22-2010 12:53 PM
It looks like you should open a TAC case.
Hope it helps.
