WRV200 router and Wireless isolation
Mar 22nd, 2010
I have a WRV200 router and I set up three SSID on it. In one of the SSIDs I disabled wireless isolation. But for some reason two wireless computers in the same SSID can not reach each other. If I put on computer on the wired network it can reach the other so it's not something with the computers.
I can not ping each other within the SSID.
What should I try to slove this?
Attila
lignartbt Tue, 04/06/2010 - 06:32
I found out what the problem was.
In the WEB interface of WRV200 there is an error. If I set Wireless Isolation (within SSID): disabled then the isolation is enabled, so the computers can not see each other within the same SSID. If I set it enabled then it is disabled, so the computers can see each other.
Maybe a fix would be great for this.
Attila Mesterhazy
Related Content
Trending Topics - Security & Network
