CiscoView 6.1.9 not showing one X2-10GB-SR on VS-S720-10G
Mar 19th, 2010
There are two Ten Gig interfacaces on each VS-720-10G on each chassis of a VSS 6509.
Only one of them on each chassis, the port 5, is being shown.
See the details on the attached file.
All CiscoView packages are update as today.
Joe Clarke Fri, 03/19/2010 - 15:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Nothing is attached, but it sounds like you may have found a new bug.  II see one other SR open reporting the same type of problem, but there is currently no resolution.  I recommend you open a service request so your problem can be analyzed and tracked.
rgomes Mon, 03/22/2010 - 07:48
Thanks. I dont know why, but I was getting error when uploading a .doc or .docx file.
Then converted it to .pdf and it was uploaded.
I will follow your advice and open a SR for this problem.
