ASA VPN Plus = SSL VPN??
Answered Question
Mar 22nd, 2010
I have a FO pair, I need to swap one ASA5520 which has a 750 VPN Plus license
Can I use an ASA5520 with ASA5500-SSL-750 instead
Best Regards Tony
Correct Answer by ksirupa about 6 years 10 months ago
Yes, it is still available to order. Part Number: ASA5520-VPN-PL=
Also, this ASA VPN Plus would be much much cheaper than the SSL VPN license.
Kiran
Overall Rating: 5 (1 ratings)
ksirupa Mon, 03/22/2010 - 08:29
No, Plus and SSL are different licenses. Failover requires identical licenses (unless you are running ASA 8.3).
tholmes@cistek-... Mon, 03/22/2010 - 08:41
Hi Many thanks for the quick reply
Is the 750 VPN plus license still available to order, do you know?
Best Regards Tony
Correct Answer
ksirupa Mon, 03/22/2010 - 09:05
Kiran
