Migration to CUCM 7
Mar 22nd, 2010
What is the CUCM Upgrade Path to upgrade from 4.1 CUCM to CUCM 7.1?
Overall Rating: 5 (1 ratings)
David Hailey Mon, 03/22/2010 - 08:38
If you have supported hardware, you can migrate directly from 4.1(3) to 7.1 using Data Migration Assistant (DMA).
The easier path; however, is to purchase at least a new Publisher (assuming your other servers can support the software installation to perform as Subscribers).  From there, you would run DMA on your existing 4.1 server and import onto a new Publisher.  This would mean new IP and hostname for the Publisher (which isn't a big deal).  However, you would be able to easily back out given that the old 4.1 Publisher is still in place.  Once the Publisher is in place and you are comfortable, you would ugprade your Subscribers.
Please rate helpful posts!
rob.huffman Mon, 03/22/2010 - 08:44
Hi Thomas,
Just to add some reference material to the great tips from my friend Hailey (+5 "H")
Upgrading to Cisco Unified Communications Manager Release 7.0(1) from Cisco Unified Communications Manager 4.x Releases
Gathering Information for an Installation
Here are some other excellent references;
System Installation and Upgrade Manual for IP Telephony Enterprise and Midmarket
Cisco Unified Communications System Documentation
Cisco Unified Communications Compatibility Tool
Hope this helps! And best of luck!
