Translation Rule
Mar 22nd, 2010
in our company will for outbound calls the number shown without extension 54774-0 and it works fine
now one employee is to be displayed with extension 54774-20
my translation rule are
voice translarion Rule 7
rule 1 / 20 / / 5477420 /
rule 2 / .* / / 547740 / type any subscriber
voice translation-profile ALL_BRI
translate calling 7
it works this way or should I change it?
Maulik Shah Wed, 03/24/2010 - 17:44
Minor edit
voice translation  Rule 7
rule 2 / ^2.$/ / 547740 / type any subscriber
Changed rule 2 to be only for internal extensions - assume your internal extensions are two digits - you can change that as you wish. You can also test the translation rule by doing:
test voice translation-rule 7 20
to see the result
