IOS LAN2LAN IPSEC VPN with UDP Encapsulation
Mar 22nd, 2010
Is it possible to have a LAN2LAN VPN between 2 Routers but using UDP Encapsulation (NAT Transparency) instead?
I was looking for a quick example but most refer to VPN Client Solution.
Todd Pula Mon, 03/22/2010 - 09:54
This is the default behavior for IOS based IPSec endpoints.  During the phase 1 negotiation, both devices will identify whether NAT is present in the path between peers and will utilize UDP 4500 encapsulation automatically.
pavlosd Mon, 03/22/2010 - 22:49
I was more looking at the commands that enable or disable this feature? Or I was wondering if you can "force" udp encapsulation even if there is no NAT in the way (for whatever security reason).
I also found the examples below.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094ecd.shtml
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftipsnat.html
Thanks.
Todd Pula Tue, 03/23/2010 - 07:00
You can disable NAT-T support in IOS using the "no crypto ipsec nat-transparency udp-encapsulation" command.  NAT-T is negotiated between Cisco endpoints and cannot be fixed.  Without NAT-T support, IOS will continue to encap using UDP 500.
