Site to Site VPN ASA5500 to a VPN Concentrator
Mar 22nd, 2010
Good Afternoon,
I woulder if any one could help we are trying to get a Site to Site VPN Tunnel up and running between a couple of our sites but it appears that it isn't leaving our firewall.
doing a packet trace we get this:
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group Inside_access_in in interface Inside
access-list Inside_access_in extended permit ip object-group SystemsServers any
access-list Inside_access_in remark Requires Access out to obtain Software updates from HP, Observer and other apps.
object-group network SystemsServers
description: Systems and Comms server that download apps.
network-object host BRSYSTEM3
network-object host BRSYSTEM1
network-object host KESYSTEM2
network-object host KESYSTEM1
network-object host BRInsight
network-object host BRSYSTEM2
Forward Flow based lookup yields rule:
in  id=0x5fa8e10, priority=12, domain=permit, deny=false
hits=9749, user_data=0x5fa8098, cs_id=0x0, flags=0x0, protocol=0
src ip=KESYSTEM2, mask=255.255.255.255, port=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x53d6748, priority=0, domain=permit-ip-option, deny=true
hits=137989867, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip=0.0.0.0, mask=0.0.0.0, port=0
Phase: 5
Type: VPN
Subtype: encrypt
Result: DROP
Config:
out id=0x5b1ea08, priority=70, domain=encrypt, deny=false
hits=549, user_data=0x0, cs_id=0x5d42738, reverse, flags=0x0, protocol=0
dst ip=10.17.124.67, mask=255.255.255.255, port=0, dscp=0x0
Result:
input-interface: Inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
I have attached a clean copy of our running config.
Thank you in advance if you could help.
Jennifer Halim Mon, 03/22/2010 - 22:48
  • Cisco Employee,
Crypto ACL needs to be mirror image between the ASA and VPN Concentrator.
Currently on the ASA you configured the following:
access-list outside_1_cryptomap extended permit ip any host 10.17.124.67
access-list outside_1_cryptomap extended permit icmp any host 10.17.124.67
access-list outside_1_cryptomap extended permit icmp host KESYSTEM2 host 10.17.124.67
access-list outside_1_cryptomap extended permit ip host KESYSTEM2 host 10.17.124.67
It is really not recommended to configure other protocol than IP in the crypto ACL, and also the "any" keyword.
Normally, you would configure LAN from the ASA towards LAN of the VPN Concentrator, and vice versa on the Concentrator.
Here is a configuration example for Site-to-Site between ASA and VPN Concentrator:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008064a06f.shtml
Hope it helps.
